aviator41's avatar
aviator41
Is my butt saggy?
We've been really enjoying our new Oakmont. We've put about 1200 miles on it already which may not souond like much, but we've only had it a month. we now certainly realize the utility and wonderful opportunities having an coach affords! We've met some great people and seen some amazing sunsets.
We're pulling a heavy trailer 13.5K dry with a Ford F350. Truck pulls it just fine. the B&W hitch provides a great ride and very little chucking if any at all. I can hitch the RV by myself and I'm really getting the hang of backing. the wife and I now have a good system for getting it backed into tight spaces.
This trailer DOES sag the rear of by truck, by a few inches actually, and I don't like how it looks. Is my next logical step from the stock suspension a set of air bags? I know firestone makes a great set and I'm willing to spend the money on a good setup.
Other than leveling the truck, what other advantages or disadvantages are there to using air bags to level the truck? if I install, it will have onboard air and an auto level setup, but the plan is to only do the rear axle at this time.
So let me have it. I need opinions and advice on getting the truck running level down the road.
Moderator edit to re-size picture to forum recommended limit of 640px maximum width.
  • Old-Biscuit wrote:
    2016 Ford F350 Lariat 4X4 and Oakmont 15.8K dry does NOT provide much info
    Truck....
    Gas/diesel - DIESEL
    Super Cab/Crew Cab - CREW CAB
    SRW/DRW - DUAL REAR WHEEL 4X4
    Gear ratio (3:55/3:73/4:30) 4:30 GEARS
    Trailer.....
    GVWR 15,800O dry, unsure of loaded.
    Pin weight right at 3050lbs at 15.8K
    Sag by a few inches????
    2" is a few to some
    4" is a few to others
    sag is 1.8 inches
    sag is 1.8 inches
    Headlights pointed up ----truck sits level?? lights do point up slightly. haven't been flashed yet, but haven't done a lot of night driving with it either.
  • 2016 Ford F350 Lariat 4X4 and Oakmont 15.8K dry does NOT provide much info
    Truck....
    Gas/diesel
    Super Cab/Crew Cab
    SRW/DRW
    Trailer.....
    GVWR
    Pin weight
    2" is a few to some
