Bedlam
May 24, 2016Moderator
Make sure the filters you guys are using are for gravity fed high volume applications. I have run into some fuel filters that were restrictive in low fuel pressure applications also causing starvation at higher loads. I have been using the filters for outboard motors with marine external tanks with good success.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
