nayther
May 25, 2016Explorer
I'd check that fuel line with some air for a leak. Take it loose at the tank and plug it, then put about 10 psi in it and see if it holds, check for leaks with soap bubbles. You may have a small leak somewhere else that's causing the pump to suck air. It is possible that the joint in the tank is the culprit but I'm not convinced; if it was that bad of a leak I'd think the fitting would fall off. Maybe JB weld it together?
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
