Rambino
May 25, 2016Explorer
Bedlam wrote:
Make sure the filters you guys are using are for gravity fed high volume applications. I have run into some fuel filters that were restrictive in low fuel pressure applications also causing starvation at higher loads. I have been using the filters for outboard motors with marine external tanks with good success.
Do you have more info on the filter you use? Make, part #. A search came up with a variety of filters. The photo shows a filter with threaded fittings. Would have to add Threaded fittings to fuel hose. Increasing the possibility of leaks, air suction. I wonder if filter location could be a issue as well.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
