MFL wrote:
I think many are being mislead by the parking lot pic! That FW loaded, will have well under 2K pin weight. That truck, 250 with 350 suspension is not going to sag, or require suspension help. I have the same truck, with more pin wt, and very little squat. These 250s still have a 2" block vs a 4" block for the 350, so they sit mostly level when empty. While mine squats about an inch loaded, it could easily take more pin wt, without any further suspension enhancement.
Jerry
I'm thinking that you're right Jerry. It's a new to me rig and I haven't noticed the rear going down very much when taking the load off of the jacks. Your 1" squat reference should give me a good starting place. I still have it on the truck so I'm going to measure the distance between the back tire and the wheel well loaded and then unloaded. When unloaded the front looks kinda high to me and I still have to wonder if it's the stiffer springs for the camper package and snow plow prep that may be bringing it up. There's absolutely 0 wagging when driving under all conditions.
I'm going to raise the pin box one hole and be done with that unless I find that my rear really is sagging after loading.
Danny
