Goostoff wrote:
I used to have a huge chucking problem with my old Curt hitch. Once I switched to the B&W Patriot last year it was nearly gone. I seen one of those anderson hitches last year. Make sure the part on the pin box is god and tight so it can not move under the weight ****fing of the trailer.
Apparently you had a pretty sloppy hitch if the B&W cured your chucking. The cheapest hitch in the world would not cause chucking if everything is solid ,and there is no movement between the jaws ,and pin or back, and forth movement in the hitch itself.
