MHay's avatar
MHay
Water inside axles - normal?
2017 Jayco Jayflight with Lippert 4400 axles. I’ve been getting a trailer wiring fault message from my truck which is related to the brakes (the brakes are now only intermittently working). I’m trying to trace the issue and I noticed that as I pulled on the brake wires that cross inside the axles they were wet and a bit muddy. I had recently driven in heavy rain, but I was surprised that so much water would be inside the axles. Is this normal or should I be concerned? I’m contemplating drilling a small weep hole under the axles for the water to drain out but not sure if that’s advisable.
