minnow
Aug 25, 2014Explorer
Transfer case has an engineering defect where an internal ring will vibrate against the housing eventually causing a small pin hole in the housing. For more than you'd want to know on this see this:
Pump Rub
Also brake/transmission/oil cooler lines rusting out is a known issue too. But that's not confined to the Chevy/GMC 8.1 trucks but rather many from 2000-2009.
Pump Rub
About Fifth Wheel Group
