jkwilson
Mar 15, 2018Explorer III
Cummins12V98 wrote:
"Don't know why some continue to push/argue trailer aid type"
He did not say "TrailerAid" he said blocking.
Below is what the OP said. The TrailerAid is a product he should consider. That is why I posted a pic of my MobileSuites setting on one.
" The biggest difficulty is the fact that there is no plate under the axle, just the U-bolt."
The Trailer Aid accomplishes the same thing as blocking. Both lift the other axle, which works very well with closely spaced axles, but as the space between them increases, the lift height required to get the second axle off the ground increases. I had my front wheel on 10" of blocking and the back wheel was still on the ground.
About Fifth Wheel Group
