riltriExplorerJul 25, 2021Jacking up 5th wheel?When you jack up your 5th wheel do you: - place the jack under the axle between the hanger u-bolts - jack up the frame - use a ramp to drive the good tire onto - other...please explainShow More
fj12ryderExplorer IIIJul 25, 2021Yep, under the U-bolt, to change a tire. Under the frame for suspension work along with under the U-bolt.
Related Content5th Wheel took out rear window5th wheel jackJacking up 5th wheelJacking up a 5th wheelAlliance 5th Wheels
