kaydeejay wrote:
rhagfo wrote:
..............The issue for me jacking on the frame, is that it is so high, and you need to raise about 6" to 8" to get the tire off the ground.
Not to mention what that does to torque the frame if the front legs are down!
That's why I only jack up my fiver when it's hitched to the truck; that way it can rotate if needed.
And I jack under the U-bolts.
Both good points here from Russ, and Keith. I have heard people say "you don't need to be hooked to truck, to lift side of FW", but I wouldn't do it with the landing gear down.
Just so much easier to change a tire, by lifting the axle an inch or so, than to lift frame high enough to raise the wheel.
Jerry
