Cummins12V98 wrote:
CumminsDriver wrote:
Cummins12V98 wrote:
IMHO this is a great item to use for maintenance and the road side repair. TrailerAid Plus
This was along Hwy 1 CA
That tire doesn't look like it's under any stress from taking all the load. Are they 17.5's ?
GY "H" 17.5" tires with about 105PSI no where the MAX.
Fine in your situation, but with a suspension built like a brick s*** house, you are fine, but some less expensive rigs may have an issue! I will stick with the 12 ton bottle jack, works better than a floor jack in a gravel storage yard.
