Sandia Man wrote:
Preferably under spring hanger/u-bolt but looks like he was right next to it from photo.
X 10 or so, this works, directly under the spring is better, but with the wood and tight to the U bolt works.
The issue for me jacking on the frame, is that it is so high, and you need to raise about 6" to 8" to get the tire off the ground.
Under the axle you only need to raise about 2" total to get the tire 1" off the ground.
IF I need to lift off the ground then I will build cribbing under my bottle jack so it is stable.
