NMDriver
May 31, 2017Explorer
My harbor freight has 6 ton jack stands on sell for $34 and 3 ton for $21.
This is how I put my 10,000lb 5er on 4 jack stands to flip the axles.
I was able to lower the front of the 5er using the landing gear as far down as they would go. Then I put jack stands about 6 inches behind the rear axle. Next raise the front using the landing gear until the wheels lift off the ground. Then put another set of jack stands 6 inches in front of the front axle and lower the 5er onto the front jack stands. The 5er was suspended on the 4 jack stands, but the wheels were barely touching the ground and could be removed to give access to the axles.
For safety sake I added more jack stands behind and in front of the main jack stands because I happen to have 8 jack stands and figure more is better, but with the 4 six ton stands I do not think the extras were necessary.
About Fifth Wheel Group
