BarneyS
Sep 22, 2017Nomad
On my trailer, the only way to remove the blind was to first remove the valence and the valences are held on by screws up through the top to L brackets. The L brackets are screwed into the wall and then the valences are screwed into the L brackets.
I purchased a long (about 12 inch) Phillips screwdriver and was able to pull up the blind, reach behind it and get the screwdriver into the screw to remove the valence. Putting it back on was a bit harder but not impossible. I also found that it helped at first to remove the screen so I could get my head and eyeball under the blind to see up there. Good luck.
Barney
Barney
About Fifth Wheel Group
