MFL
Apr 24, 2015Nomad II
Lyle, I think the floor plan of the Jayco is much nicer than the Cruiser 27. I think you should be comparing the CAF28SE, to the Jayco. It is the same floor plan. Yes, it is a shade heavier, but not much.
I happened to see the exact Jayco, at a local park. It is nice looking! The only thing I noticed, when looking at the model sticker, was that it had 4400 lb. axles. If the Cruiser had 5200 lb. axles, that would be a plus. You'd get bigger brakes, bigger bearings, and a more stout tube.
I wouldn't be afraid of a little more weight on your 2500, even if you had to add a little suspension enhancement.
I think the opposing rear slides are a nice feature.
Jerry
Jerry
About Fifth Wheel Group
