JEBar
Jan 27, 2014Explorer
I believe the Jayco is a much better built unit with a much larger base of dealer support .... it has a stronger frame which can be fitted with a 4 point auto leveling system .... Open Range has cut its frame to where in order to support it and keep it from bouncing takes a 6 point system .... on top of the 6 jacks they usually require additional stabilizer bars between the jacks .... while some think they are fine, they also use the cheapest (cable) slide system on the market .... they do a good job of spinning their system to make it look good but spin is spin .... if you are going to park it most of the time, they are OK .... if you plan to travel, the Jayco is the way to go
Jim
Jim
About Fifth Wheel Group
