Lantley
Jan 28, 2014Nomad
JEBar wrote:Trail-Mate wrote:
JEBar is way off base on his OR comments. 4 and 6 point systems and standard JT strong arms are an upgrade from most systems in this price point.
facts are facts .... a frame on which a 4 point leveling system without any stabilizers can be used is much more solid/rigid/strong (pick the term you like) than a frame which requires 6 jacks plus JT's stabilizers .... as noted, Open Range uses a slide system that cuts weight, they also cut weight in their frame .... for some folks that is fine .... for others it is a point of concern
Jim
They also do not bore sizeable holes in their main beams.
It's all related.
About Fifth Wheel Group
