campermama wrote:
Can you tell me if the black part in this picture is the check valve? And anything I should know about taking it off besides draining the tank??
Thank you!!
https://gopro.com/v/nrvLm925ewJMZ
I can't tell from the photo, when I enlarge it the resolution is so low that it is just a blur. It most likely is the check valve, you will know when you take it apart. You will need to cut the red PEX tubing to disassemble. PEX tubing needs a special tool to crimp it on, so while at Home Depot buy the fitting(s) that needs no special tool, Sharkbite is one brand.
This check valve may work.
