We have the T32C Octane and have had a few issues in the couple months of ownership and really only one trip so far, such as water heater control board failed after one use covered by warranty, actually was able to just send board to dealer and they sent new one back not sure all dealers will do that. Had issue when using shore power seems when they connected the external plug they cut the red wire to short and instead of re-doing the wires they bent the others hoping they would not bend back well they did and the wire came out that took some figuring out. Those were the two big things there were other small things that would plan on the dealer having to fix once you go through your PDI. All in all seems like the build quality of the materials is there just not the fit and finish was expecting for the price. Notice yours has a pocket door as well make sure check to see if square when closed. run roof vent fans with lights on as will show any shorts as we found out, don't believe the hitch weight they tell you add a couple hundred pounds dry. Hope this helps
