mufcn01's avatar
mufcn01
Jayco Polar Bear Package
I am heading north to Alberta after wintering in AZ. It looks like I will hit some -10C overnight temps. I'd rather not winterize the unit and I don't like the idea of towing with the heater on. Is the Polar Bear package enough insulation to prevent freezing of my waterlines etc.?
  • Thank you for the update, good to know we can rely on the Polar pkg to keep the trailer toasty and not freeze.
    Unlike you, we are winterizing now and not Rv ing until next spring :(
    have good time
  • A final update on the question I asked back in the spring. It was -13C in Lethbridge and remained cool for quite a while once we were home, north of Edmonton. I kept the trailer plugged in in my driveway and eventually went and dumped water and sewage and there were no problems at all. It was a cold spring in Edmonton so I hope not to have to worry about this in future. Thanks for all your feedback.
  • Cold temps and 60 mph 'breeze' could combine to freeze up ,I would try to drain on last day of travel.
  • mufcn01 wrote:
    Thanks everyone for your helpful comments. I am in St George, Utah and it was well into the 90's today....hard to believe I'm even asking the question! We are doing about 7 hours a day...Brigham City tomorrow, then over the Monida Pass to Dillon, MT, then Lethbridge, AB, then home to Edmonchuk My main worry is freezing up the pipes...so if the RV is warmed up once we stop, it sounds like I should be OK, but if in doubt I`ll open the low point drains as suggested.
    Edmonton just received 20 cm of snow :E
    I was told by the dealer to consider blowing the lines out when returning from our trip to the OBX late April if the weather stays this cold.
    We have a Jayco Eagle with the polar package.
  • Thanks everyone for your helpful comments. I am in St George, Utah and it was well into the 90's today....hard to believe I'm even asking the question! We are doing about 7 hours a day...Brigham City tomorrow, then over the Monida Pass to Dillon, MT, then Lethbridge, AB, then home to Edmonchuk My main worry is freezing up the pipes...so if the RV is warmed up once we stop, it sounds like I should be OK, but if in doubt I`ll open the low point drains as suggested.
  • Open Your low point draines and a tap,it will remove enough that you won,t have to even worry about it,have done it many times with no issues,
  • the main unit may be winter resistant with dual pain windows, extra insulation, etc. but are the tanks and below floor piping, etc. well insulated. I think it all depends on how much time is spent traveling where things could cool off.
    bumpy
  • which Jayco camper do you have .... their Eagle, Pinnacle, and Seismic lines have all been independently tested and certified from 0 to 100 degrees .... along with their JayFlight units that come with an upgraded insulation package, so long as the camper's furnace is working, I wouldn't be to worried about -10
    Jim
  • How many hours is the drive per day and the daytime temps?
    Otherwise I think you are fine while in use each night.
    If you're talking about driving without the heater on, you should be fine.
    WoodGlue
