Bigmoss's avatar
Bigmoss
Jayco Thermostat ?
I am finalizing a deal on a 2015 Jayco Eagle and noticed from all the pictures the dealer sent me that it has the cheaper style thermostat with the sliding bars.
Has anyone updated theirs to a digital thermostat ? If so what model and was it plug and play ?
Please post a pic if u have one
  • Yup, that's the one I installed and that link is a great price!
  • Did you read my post above....?
    I gave you a direct link to exactly what you are asking for...and to what Nodaker is referring to.
  • Nodaker wrote:
    There are many threads showing the wire-to-wire conversion to various standard digital thermostats which are inexpensive.
    I swapped out the Coleman-Mach analog in my 2015 Jayco with the exact Coleman-Mach Digital. It was more expensive (about $60 I think) but it was a simple direct wire-for-wire color match conversion. I think it was worth not having to 'jury-rig' the wiring and a 2 speed fan switch.
    Search Google for a vendor, there appears to be less expensive options than offered by Amazon.
    Do you have a link to the one you used ? Mine the the Mach Analog
  • There are many threads showing the wire-to-wire conversion to various standard digital thermostats which are inexpensive.
  • Not sure what Jayco is using...but there are many options for converting from analog to digital stats.
    If You have the basic Coleman-Mach this is a ready to go strait swap option. (comes in black or white) However it is non programmable.
    You can also go to Home Depot and there should be a number of options but you will have to add your own hi-low fan switch if you want that option.
    Digital Thermostat LINK
