Mile_High
Feb 04, 2015Explorer
Jeep in the Back
Anybody tow a Jeep behind their 5th wheel - 4 down? Just curious how well it does. I've seen a couple of horror stories where one rolled, but since then I've seen a few on the road.
MPI_Mallard wrote:
I would worry about the excessive swing behind a fiver (mine is almost 12') yanking a car around a corner and I know that these states (in red)consider anything attached to the rear of my fiver to be "triple towing".
http://i728.photobucket.com/albums/ww289/MPI_Mallard/DoubleTowing.jpg
Red Green:
They say necessity is the mother of inve
ntion. Don't know who the father is;
probably remorse.
Jim-Linda wrote:
FWIW, its double tow not triple, truck pulling trailer(one tow), jeep(two tow)
Jim
rgwilliams69 wrote:You are very close, and thanks for the Jeep weight, I was guessing! My GVWR is actually 17,500, and I'm pushing 17,200 when loaded with water. Hitch is a 26,500 OEM Ford/Reese. Hitch in the back is rated for 3,000 lbs, but I'm not totally sure I trust it without some work. Length is going to be close (OK for CO at 70') in some states that allow triple tow. Brakes might be an issue. I don't know the rules on brakes. Also my pin box is a weak link, as it is only rated 18K (tri-glide).
I found the listed curb weight at 2,273 pounds ('71 CJ5 Universal) so you are pretty close. I'd agree that your weak point will be the truck engine, transmission, and GCWR. However if you are within that tolerance the truck should be built to do it.
Your Redwood max GVWR (if loaded up) is 16,500. Jeep would be 2,273. Truck 9,200 or so (loaded up with passengers, fuel, etc.). Total on all that is 27,973. Sweet! Assume you have the Crew Cab 4x4 your GCWR is 30,500, so you should be good to go if you want to try it. I had a 2012 F350 DRW with the 6.7 engine and those things are beasts.
That would look pretty cool motoring down the road!
