bbaker2001's avatar
bbaker2001
JT strongs
received my JTs
I always see them attached to the very bottom of the legs, I use a set of blocks so I don't have to put them all the way down. also helped with stabilization. should I eliminate the blocks and put the legs all the way down
  • bbaker2001 wrote:
    received my JTs
    keep the blocks...the less leg out the more stable
  • I just added JT's on the front. They seem to lock the fronts tight without using blocking. If I'm on a slope, I suppose that I'll need blocks, but otherwise I'm going to see how tight it all is without them.
