oldtrojan66
Dec 07, 2014Explorer
Snowman9000 wrote:
Use spray foam sealant, or 0000 steel wool (the coarsest size). Only use steel wool if it won't be exposed to the weather or road spray.
I used some brass wool instead of steel just for the rust problem. Stuffed all the holes I could find, then filled in with foam sealer around the brass. Seems to have worked pretty well.
A side thought... I wonder how many of these other "remedies" we would be so fond of if they didn't smell so good? I have used them as well, and it could be worse if they smelled like dirty feet!
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
