CabinetmakerII
Oct 28, 2013Explorer
HucksMomma wrote:
Last week we purchased a 2006 Rage'n 2600FS and are still trying to work out the kinks....
Went camping this weekend with weather in the low 20's and found out the heat was not working.
Propane was full... Any suggestions?
Also,
The pump for the fuel center is not working.
Other than that, the TH is in immaculate condition. It was rarely used and we are very impressed with it.
As for the fuel pump... Mine quit working during a 2 week hunting trip this fall. I had read on another forum to remove the plastic impellers and "polish" or in my case "sand" one side of the impellers and reassemble. These plastic impellers will swell and rub on the housing preventing them from turning. Just a couple of passes on some 220 emery cloth should take care of the issue. That is of course assuming the motor turns with the impellers removed. The hardest part was to reinstall the pump into its original position. My shoulders just don't work the way they use to. Good luck!
About Fifth Wheel Group
