Scott16 wrote:
I actually have an 1800 watt inverter that runs the home compressor just fine. On the road I have an MV-50 12v compressor that has served me very well.smkettner wrote:
First thing would be 200+ watts of solar power. If I need air 24/7 I am looking for hookups.
Then a small ~300w inverter to charge the small stuff and run the satellite, tv. Large inverter (1500+ watts) really need four batteries. So it gets to be quite a jump to go "all in" with some of this stuff.
If you need a portable air compressor.
You can get a small portable 110 volt Black and Decker unit at sears. You do need a portable Generator to plug into.
Just information for you.
Scott- VeebyesExplorer IINot FT but what I call extended traveler here. Each trip is a minimum of 2 months.
First priority is as much amperage battery bank as possible. We have a single 4D AGM battery. About 220AH.
Next is a genny to charge it. The Honda 2000 works just fine for this.
Power use management is done with an inverter/charger, just like boats. No converter.
Battery charging is done when there is the most demand for power such as mealtimes, breakfast & dinner. The inverter takes care of light late night loads such as the TV. The fridge stays on propane when drycamping & the water heater is only turned on maybe 1/2 hour before needing it for showers. No point is leaving it on 24hrs when dry camping. - cabanamanExplorerCarried my generator for two years and never used it.Left it in storage for this year and needed it twice!! I did use my 2000 watt inverter instead.Ran everything but the a/c and worked out well.
- Scott16Explorer
Scott - Old-BiscuitExplorer III
willutfid wrote:
Hey, Old-Biscuit, approx how much did this set-up run you?
Roughly 7 yrs. ago
Gen/box---installed was $3900
The extra receptacle on 5'vr front was $500 (receptacle, wiring, panel, breakers)....no labor I work on my stuff for free.
Think the same set up for gen/box is closer to $5000-5500 now.
If I had it to do over.......still would do the same. - willutfidExplorerHey, Old-Biscuit, approx how much did this set-up run you?
- First thing would be 200+ watts of solar power. If I need air 24/7 I am looking for hookups.
Then a small ~300w inverter to charge the small stuff and run the satellite, tv. Large inverter (1500+ watts) really need four batteries. So it gets to be quite a jump to go "all in" with some of this stuff. - BumpyroadExplorer
rhartman911 wrote:
My daughter has an onbord generator and just brags about how nice it is just to push a button and not have to go outside but it will go out someday and then I will ask her how much she loves it when they are forking out the MONEY
that convenience is priceless, IMHO.
bumpy - barney_bugleExplorerThanks for all the info guys ,Lots think about.am heading south to see more of your beautiful country in october and will check around for prices then . many thanks.
- Old-BiscuitExplorer IIIWhen we decided to go FT......I wanted a simple generator set up.
What do I mean by simple?
Doesn't take up any storage room that I would regret losing and one I didn't have to move/strap down/relocate
Self container....own battery/fuel tank
Enclosed/weather proof
And 'quiet'
Decided that I wanted an in-bed generator so I got one of these.....LINK
It sits in front bed area that I had no plans on using for anything else (no loss of storage)
It has it's own battery/fuel tank (charge line from my truck battery)
It is fully enclosed (rain/sleet/wind/snow....no problem)
And with the design of the exhaust it is really pretty dang quiet.
Plugs into a receptacle I added to front of fiver and will run everything in rig........30A so load management is used (common sense)
The additional receptacle up front comes in real handy.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
