djgodden's avatar
djgodden
Just weighed...
Just got weighed and this is what I got. (With people and full fuel tank, fiver tanks empty except for 1/3 water.)
TV Only: steering 4740, drive 3260
Full rig: steering 4800, drive 6240, trailer 9520.
TV: steering GAWR 5500, drive GAWR 6010, GVWR 8800, GCWR 22000
Trailer: GTWR 1980, GCWR 9030
I'm concerned...
  • GVWR corrected and yes, GTWR is correct. My 2012 4x4 Ram Laramie Longhorn w/6.7 Cummins HO (350HP/800T) has Load lifter 5000 bags w/30 psi when towing. Rides level, rear tires set for heavy load at 80 psi. Rear tires are as described above, **** it. Unfortunately I replaced 2 12v batteries with 4 6v batteries @76 lbs each. Seems I shouldn't have done that.
  • rhagfo's avatar
    rhagfo
    Explorer III
    TV: steering GAWR 5500, drive GAWR 6010, GAWR 8800, GCWR 22000
    I'm concerned...
    You need a bigger TV and lose some weight in the 5er! :S
    Would love to see a picture, and how you deal with that heavy rear axle.
    #1. that 2012 has the same GVWR as my 2001!
    That said you are way, way over the TV GVWR at 11,040 on the TV. I thought I was way over at 10,000# on the TV. :B
    What is the Max load rating on the tire side wall if 265/70-17E they are rated at 3,195 X 2 + 6,390 putting you right at the edge of the tires.
    Your 5er weight is over its GVWR at 12,500#, your 5er has a GVWR of 12,220#. You are just shy of 24 percent pin weight.
    Your TV before hooking up weighs in at 8,000#, leaving only 800# of available payload before exceeding the GVWR.
    I weigh in at about 7,800#, and run right at 10,000# +/- with the 5er attached.
    Model 2955RL
    Shipping Weight 9,895#
    Carrying Capacity 2,325#
    Hitch 1,820#
    GVWR 12,220#
  • Just got weighed and this is what I got. (With people and full fuel tank, fiver tanks empty except for 1/3 water.)
    TV: steering GAWR 5500, drive GAWR 6010, GAWR 8800 are you sure this is not the GVWR?, GCWR 22000
    Trailer: GTWR 1980 is this correct???, GCWR 9030
    I'm concerned...
