ajriding's avatar
ajriding
Explorer II
May 14, 2021
Tongue Weights weighed
I finally weighed.
Someone said something about having no WD hitch and the rear axle as a fulcrum unweighting the front axle, so I did math. I weighed my small trailer only so far.
I weighed about 350 lbs tongue weight. Not a lot.
the distance from rear axle to ball.
the distance from front axle to rear axle.
I divided the wheel base by the distance from rear axle to ball and got about 2.8 then divided that into the 350 lbs to get a number that I think represents the upward lift on the front axle.
So, 350 lbs pushing down on the ball will push up the front axle about 125 lbs (unweight the front end by 125 lbs).
This does not seem like much.
If you made a teeter-totter with similar distances and put 350 on the short end and 125 on the other then it would balance equally.
Add that I will have a small genny hanging from the front receiver hitch (50 lbs) cantilevered out which will multiply its weight slightly too, but I do not always have it.
So, with no WDH I am unloading the front end by 125 lbs at worst. Hit some bumps and I still do not think it will matter much.
Figure the motor and trans are at the front, so Im wondering how much weight will it take to create a situation where steering and unweighted front axle makes a safety concern.
I added airbags so that I can ditch the WDH as tired of removing WD bars for the last few miles of a trip up messy dirt roads, so I ran the numbers...
Im late for work now, so sorry if I explained it not-the-best...
Anyone else run similar numbers?
