FLY_4_FUN
Nov 26, 2014Explorer
First off how many amps is the socket you are plugging into. If its a standard 15A plug-in, then it should run your rv fridge, convertor and lights...pump etc. I would assume that you have a "high load" item that is still on despite your checks. Check that your electric hot water heater isn't on. Also confirm that the wiring to your rv batteries are in order and nothing shorting. I suspect something is still pulling power, or perhaps your plugging into a socket that is already loaded in your house and it cant take the load of the rv.
Daryll
Daryll
About Fifth Wheel Group
