Terryallan
Nov 27, 2014Explorer II
FLY 4 FUN wrote:
First off how many amps is the socket you are plugging into. If its a standard 15A plug-in, then it should run your rv fridge, convertor and lights...pump etc. I would assume that you have a "high load" item that is still on despite your checks. Check that your electric hot water heater isn't on. Also confirm that the wiring to your rv batteries are in order and nothing shorting. I suspect something is still pulling power, or perhaps your plugging into a socket that is already loaded in your house and it cant take the load of the rv.
Daryll
Also. Find out what in the house is on that circuit as well. You may be running something in the home that is close to max amps, and just a little more from the 5er kicks it over.
About Fifth Wheel Group
