greende
Nov 28, 2014Explorer II
All of the above information is good advice. If you are sure the house circuit is solid, Start by turning ALL the RV breakers off. Plug the trailer in and see if it trips. If it does, you most likely developed a short or ground fault in the cord. If not, turn on one breaker at a time till you find the one that causes the trip. As someone said, the water heater is a common cause. BTW, where is the OP?
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
