Old-Biscuit
Aug 17, 2019Explorer III
Few questions...
*are the INTERNAL Fans operating (1/freezer & 1/food compartment)
DC power from P4 2 pin connector (pin 1) far bottom right on circuit board
*are the EXTERNAL FANS running (P1 10 pin connector -- pin 5) DC goes to t-stat then to the Fans
Suggestion:
Unplug thermistor leads (temp sensor on 2nd fin in food comaprtment) and let fridge run W/O temp control (set tp MAX temp setting ---then if food comaprtment gets to cold you can lower the temp setting ----operates on Backup Operating Suystem which is 'timed base' vs temp based
Suggestion:
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 14, 2026
