CObroker's avatar
CObroker
Keystone Carbon water tank leak - OMG poor quality!!!
Have to vent.
Bought a new Keystone Carbon 364 Toyhauler last August, used a couple times last year. Used a couple times this year so far.
When we picked it up we noticed a sharp looking bulge underneath in the coroplast underlayer. But since you can't just access that, we let it go and drove home. After traveling about 2500 miles on the few trips (Moab, CO mtns, etc) we noticed the bulge getting lower and it looked like something was about to pierce the underbelly since the bolts holding it were tearing thru the coroplast.
I cut the coroplast, insulation, and unbolted the sides. That literally SAVED MY FAMIMLIES LIFE!!!
Two of the water tank support bars (the frame supports) were never attached on one end from the factory so they were just being supported by the coroplast. It was the forward end not attached so that if they would have fallen, they would have spiked into the road when traveling, which would have levered the water tank, dropped the electrical wires, propane lines, and other loose hoses being only held up by the underbelly onto the highway. Probably would have been a spectacular wreck attributed to driver error, of course.
Also, the tank is apparently missing one entire support bar nearest the tank drain, intake, sensors. This has distorted the entire tank, and towing with only two bars on bent the bars that were installed about 4 inches! So the tank distortion has now caused a water leak at the main drain.
I took pics that clearly showed the bars never being attached on one side and sent them to Keystone. The response I got was 'bring it to a dealer, that's what you agreed to'.
Sadly, in the Denver area, the Keystone RV dealers have a two month wait now along with a you didn't buy it here, so we will not service your unit policy.
So supposed to have a big trip to Moab with 6 other families and units over Memorial day, and my new Keystone Carbon Toyhauler leaks and can't be fixed!
Keystone and your lack of quality control and warranty service! It's like they built this on a Friday and everyone decided to quit early to go drinking.
I'm going to try to contact the factory tomorrow and see if I can tow it back to IN from CO and see if maybe they aren't too busy pushing new units to fix this one. I'm not optimistic.
Any suggestion on fixing this are welcome.
thanks for reading the rant. $60k for nothing.
Raptor, Carbon, Fusion, Impact, Outback all built by Keystone
  • Wow, your story tops mine. See my Keystone story here: Very Dissappointed with New Keystone Alpine
    There is no point going to the factory, they will not repair it there. I speak from experience. Calling is no help either, they will tell you to open a warranty claim through a dealer. They will listen to your problems and take notes but will only review your claims via a dealer.
    It is my impression that Keystone is too big to care these days. Since the latest RV boom, they are focused on throughput and quality is far down on their priority list.
  • Call Keystone see if they can put pressure on a dealer to get you in quicker, or see if they can authorize a mobile RV tech to come look at it.
