My king pin does not seem to sit deep enough in the hitch causing slide bar to have trouble sliding over the bottom flange of the king pin. Anyone have an issue with this, are there certain king pin/h...
Helped a fellow rv'er in Montana last summer, could not get his hitch to latch, it came down to removing his lube plate, it was beat up a little , and holding the kingpin up just enough that it wouldn't latch. It worked fine once the plate was removed. Apparently some pretty close tolerances on those kingpins or hitches.
