wdgold's avatar
wdgold
King Pin fit?
My king pin does not seem to sit deep enough in the hitch causing slide bar to have trouble sliding over the bottom flange of the king pin. Anyone have an issue with this, are there certain king pin/hitch combos that don't seem to work well.
  • Cummins12V98 wrote:
    Are you using a slip plate? If so Hensley sells a 1/8" thick one.
    I had one on it made it worse so I had to take it off
  • Not with a slide bar, but have seen this with a 1" plus dual jaw, and using a rather thick lube plate between pin box and hitch head.
    Jerry
