Good, Bad, or not worth it? we have a 29'er...DW is wondering if a King Pin stabilizer is a good thing or not....advantages, disadvantages? Are some better than others? Comments appreciated....
When I use the Untra-Fab 5th wheel tripod under the tongue, I bring th 5er pin down into the cup and put some weight on the tripod from the pin box. You'll hear the weight of the 5er settling on the tripod...and thats when it really cuts the movement when used in conjunction with your stabilizer jacks. Also using Lynx Leverlers under the sissor jacks and extending the jacks as little as possible helps dial out the "jello wiggle".
