DBECHEN
Dec 31, 2017Explorer
King pin weight
Have some questions on trailer weight and pin weight. We have a 2007 GMC 2500HD short bed 4x4. Just weighed it today on a CAT scale. Was loaded ready to go with generators extra propane tanks and fuel...
CWSWine wrote:Old-Biscuit wrote:CWSWine wrote:Old-Biscuit wrote:CWSWine wrote:
Ok, you say for warranty post a link to creditable site that says that not just take my word for it.
To start this I will post a creditable link to site that states not to exceed and even list what might happen if you do and this one from GMC own website.
Overloading your truck or SUV can carry severe consequences,
Now your turn for a link saying it just warranty and don't worry about exceed the GVWR....I believe people should have the facts but believe me because I say true isn't a fact.
You are asking me to prove a NEGATIVE
Your link is a MFGs Recommendation with 'What Ifs'
*Broken springs and suspension components due to excess weight That is from overloading the AXLE/SUSPENSION Components....something I do NOT recommend
*Brakes unable to stop the truck or SUV in a timely manner Once again..braking ability is based on AXLE Rating
Don't exceed axle ratings
*Transmission and other driveline components may overheat and sustain serious damage
Only issue that is related to GVWR and warranty coverage could be denied. Course that applies to engine tune programs etc
*Unusual suspension behavior, making the vehicle hard to control Once again..suspension is part of the Axle Rating.
Do NOT exceed Axle
*Tire temperatures rising to elevated levels, potentially leading to a blowout
Tire Load Rating and proper air pressures
Do Not exceed........Tire Load Ratings are typically Higher then Axle Ratings so you would have to overload axles in order to overload tires.
Under inflation causes heat build up and blow outs
Bye-Bye
Let your informed conscience be your guide
Come on --- GAWR are not mention in the entire write up on GMC site it only refers to only GVWR. How did you come with they are talking about GAWR that wasn't even mention.
You do know that the axle ratings on Class A with a GVWR 33,001 pounds (14,969 kg)+ is determinded by the axle ratings and are one in the same. The Class 8 truck manufacture has several axle weight options for the same truck and axles can even be replaced to increase the GVWR/Axle ratings. You also do know that a over weight citation for Class 8 trucks contains the this statement "GVW/GAWR was exceeded"
On a Class 8 truck with GVWR over 33,001 pounds (14,969 kg)+ the manufacture assigned GVWR is the sum of the GAWR but on Class 2 or 3 truck the manufacture GVWR is less than the GAWR? Could be the axles are not week link Class 2 and 3 and some other part of the truck and in Class 8 the axles are the week link?
