2CAJUNS
Nov 07, 2015Explorer
kitchen slide noisy and jerking
I have a 6 month old 2015 Keystone Montana High Country 305RL with 3 slides. Last trip out, I purchased seal lube for the gaskets and applied. The kitchen slideout now has a noisy and jerking motion when moving in or out. It is the cable slideout type. My first thought was something out of adjustment, but the dealer said the lube I applied to the gasket on the bottom of the slide is causing the slide to drag and bind on a wear strip that is located just inside the the camper between the camper floor and the slide out floor. There are no visible rollers on this slide as on the other 2 slides. They are still working smoothly. Could this be a correct assessment of the problem or is it something else causing the dragging and noise. He told me to wash the area with 409 and water and it would get better with time. Any help or ideas would be appreciated.
