slick50's avatar
slick50
Kitchen Slide on 2012 Voltage 3950
I put the kitchen slide out on my 2012 Voltage and now it won't come back in. The slide went out without any trouble but only one side moves when I try to bring it in. I tried pushing from the outside while using the remote control but still no luck. I'm guessing that it is either a bad motor on the non-functioning side or possibly the electronic synchronizer for that slide.
Anyone have any suggestions?
  • You need to check the controller for fault codes. I cant remember exactly where the controller for the kitchen slide is but its probably in the front storage. I know the bedroom controller is in the gen compartment.
    Lippert has troubleshooting guides available. You may need to put the slide in "override" mode to get it to go in.
    troubleshooting help
  • Dutchmen left it on top of the slide where it eventually jammed. I climbed up and pulled it out.
  • joebedford, how did you get to it? Was it visible somewhere?
  • I had that problem - there was a scrap piece of electrical cable (14/2) that eventually jammed the slide.
