hvac
Sep 02, 2017Explorer
K&N oil filter
Ready to Pull the trigger and order a K&N oil filter for the 5.5 onan q.v., 2017 model. Like the 1 inch nut built on the filter. Couple of questions. Is the number HP 8029 correct for replacement o...
ng2951 wrote:I think you're talking about the air filter and he is talking about the oil filter. There are problems if you overoil the air filters, as was mentioned before. After examining the air filter on my Cummins I went to a BHAF, Big Honkin' Air Filter, as the creases of the K&N seemed to trap a lot of gook even though it was cleaned pretty frequently. I think the diesels just process too much air.hvac wrote:I had a ton of problems on my truck after using one. I think the oil coats some of the engine's inlet sensors and knocked my MPG down.
Couple of questions. Is the number HP 8029 correct for replacement of onan 122086?
Comments from those who have used these filters?
