Old-Biscuit
Jan 02, 2014Explorer III
ipeltier wrote:
Husband has been trying to locate the sound. It is not under the front cap; it is in the front storage area--there is square metal column on the right side by the winch. The sound appears to be coming from that--like something has rattled loose.
Front landing gear assembly
Are you unhooked from truck with landing gear legs down and set?
Check the anchor bolts that attach landing gear assembly to frame of 5vr. Probably 'U' shaped bolts around the upper tube.
There should be NO movement in the upper part of assembly/tube
And only a little movement in the drop legs pin goes thru
Hook trailer back up to truck for support then retract landing gear just off ground and check the whole assembly for looseness
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
