BurbMan's avatar
BurbMan
Explorer III
Jul 22, 2018
8.1L Knock and Update
Routine spark plug change and getting ready for VT trip. Plugs have 40K miles and look pretty good. All of the gaps were about the same so the electrodes were not very worn. Truck now has 181,000 miles.
Truck ran great with the new plugs, until a few blocks later the "Service Engine Soon" light pops on. Code was P0332, Knock Sensor Low Input Bank 2. Cleared the code, drove a little longer and it came back on.
The knock sensors on the big block are on the outside, not under the intake like the 5.3 and 6.0, so they aren't subject to failure due to coolant soaking that GM issued a TSB on. Aside from the sensor itself, the other likely cause was a weak spark in one of more cylinders. Since the plugs were all new and properly gapped, I figured I may have damaged one of the wires during the plug change.
A quick trip to NAPA for a set of wires, and problem solved. I took a loooong highway route with hard acceleration and high speeds, no codes returned, so am hoping this is solved. Now if I could only find my short 3/8 extension....it popped off the socket after tightening plug #7 and darned if I know where it went....
