whistlebritches's avatar
Sep 19, 2023
lamination on 5th wheel
We have a Cedar Creek 37' RDQS 5th wheel. The lamination underneath the cap has a couple of places that are sagging slightly. We have not had any leaks inside the RV. How difficult is this to repair and how expensive.
  • OP is likely talking about the underside of the front overhang. Almost all of them sag, at least a little bit, after a few years; does't mean they're delaminating.
    Lyle
  • front cap ?? Rear cap ??
    Need more tech input for a good speculation on the problem.
  • Do you mean the front cap? There were some years where heat from the sun was causing delam problems in that area. Or it could be leaking from a clearance light, etc. and that wouldn't necessarily show up on the inside.
    Either way it has to be peeled back and re-glued.
  • A bit more info would get more replies. A pic would be best!
