jims1 wrote:
Hook up to your truck and take a measurement from each pad to the ground. Use your individual switches to make them even. Run both at the same time for 30 sec. Measure again. Did one extend further than the other?.
I have the UltraFab gear set like mentioned above that runs on 2 independent switches. You have to keep equal pressure on the landing gear legs or one will overload and the clutch start to slip. Once the clutch has slipped enough you have to either rebuild or replace it.
This is a good idea. I think I'll mark the legs in 1" increments, that way I can keep track of how much each one moves.
