Wizbangdoodle wrote:
You won't be disappointed. As long as they get shipped without damage. I had to send my first set back because the wires on one motor got smashed and broken off right at the motor.
My only suggestion would be to plan out your install very carefully and it will go much smoother. I had to remount the motors on top of the legs in relation to the brackets to make them fit properly. Let me know how it goes.
Please elaborate on the motor mounting. Did you have to rotate them within the brackets? It looks like they are retained by the angles at the top and can be spun 180. Can they also be turned upside down so the motor is below the gear box? I know the rotation would be backwards but that's easily fixed by switching the wires.
