Wizbangdoodle wrote:
Good luck guys. I think you'll find you will not regret upgrading. As far as the switches go, yes, they are a bit on the cheap side. The mounting flange is just a slab of bendable plastic. I figure I'll make a custom plate and replace the switches in the future.
Wow, they must have changed since 2008 when I received my BullyDog switch panel. Mine is a real thick fiberglass board much like a PC board and the switches are real nice and in there good. I installed it with Venture legs which are a bit bent and need to be replaced. I will see the quality of the new switch when I order the BullyDog set next spring, if I can wait that long... it's been "Money-May" and my Fun-Fund is severely depleted.
