Greyhound_RB's avatar
Greyhound_RB
Landing Gear Lubrication
I have a 2012 Keystone Cougar 323 MKS. The landing gear motor seems to be straining a good bit under load. Is there any good info on lubing the shaft/nut. Thank you.
  • Good grief ...you do not need to remove/disassemble landing gear to grease it
    Some folks have drilled/tapped/installed Zerk fittings
    1 just below top cover and another one down further
    I just pop the top cover and using a plastic putty knife scrape a glop of bearing grease into it on the gear set...twice a year
    Been doing it since 2007.....simple
