fj12ryder wrote:
One of the main advantages of two separate motors is two separate controls so you can control the motors independently. They will run at the same speed so that part doesn't matter.
Yes ,but we are missing the point here or are we :), if one is binding a bit ,then no they won't run the same speed, and will have to be adjusted independently , thats the nice thing, but then again you still have to watch ,and make sure you are not coming up crooked ,and putting more bind on the legs.
Keeping them lubed up, and not over extending them to the end, and messing up the worm gear, then regardless one or two motors, they will run okay.
Mine with one motor runs fine after messing up some gears, and having to replace one, then knowing what to do.
