fj12ryder wrote:
Small hole in the outer leg, run the leg all the way up, lower the inner leg, and spray some lithium grease liberally through the hole. Easier than a grease gun, and insures that the grease ends up on the screw and not down the side of the leg.
I think we are talking about two different styles of landing gear, these are lippert or stromberg one in the same, but there are no holes other then two little ones on my 2008, directly below the cap, you can accomplish the same thing , just by pulling the caps off on them and greasing those top gears, but I don't see anyway to get grease to that worm gear ,and nut down lower. Unless I am missing something here that you are saying ????
